Issue Porting
celerykale
Hello,
Looking to port my number from telus.
Tried using the change number feature but it just keeps loading and loading then stops loading, no error message or anything.
I then tried chatbot to submit a ticket but could not get pass verify identity (information are correct), submit button just stays disabled.
Any idea what I should try next? Thank you!
Additional Information
- Telus number still active
- PM number still active and has a number
darlicious
@celerykale
Try using your phone instead. Don't forget to keep the telus sim card in the phone to reply YES to the PAT(porting authorization text) within 90 minutes of receiving it. Your port will then complete within minutes. If more than a half hour passes and your telus sim card is still working then contact the telus porting department. If Simple--Simon is unco-operative then send a private message to contact customer support.
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #.
@celerykale
The CS_Agent will get back to you tomorrow as they are off for the day.
Keep your eyes on the envelope icon on top of this Community tomorrow.
It maybe a backend issue with PM.
@celerykale
Could be a server problem right now so maybe try later or you can private message a CS Agent for assistance.
You can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
Customer Support Agents are available:
  • Monday to Sunday: 6 AM to 10 PM EST
celerykale
Thank you however same result
JK8
@celerykale
Clear your browser cache/history and then open a new window in incognito. Try chrome and then edge.
