Is there a voicemail option??
melaniemorneau
I switched today from Rogers to Public Mobile, I used to have a voicemail option, and now I have none, Is there a way to add this option with Public Mobile?
Thank you!
andriykoval
Yes voice mail is included. The fastest way is to open your phone app and press and hold " 1 " on your keypad.
@melaniemorneau, Voicemail is included in all Public Mobile plans that include calling.
This KB article explains everything you need to know about voicemail and other PM service.
NDesai
@melaniemorneau Voicemail is included as long as you have talk on your plan. To access it, dial your own number.
super8989
Unless you signed up with data-only plan, all plans include voicemail.
You can access your voicemail as you did before straight from your phone. The first time you access it, you can set a pin number and record a message.
