Is there a $25 referral bonus promo right now?
irisxiaolu
I am looking to get my dad signed up. And where do I find promo information for PM? Thank you!
JL9
Can you stack this with the one from earlier this Summer? Or will this start after the five $5 credits finish from the last one?
@irisxiaolu
Remember that the $25 credit is $5 over 5 months and not a lump sum.
irisxiaolu
Thank you very much for the confirmation!
RossN
@irisxiaolu  Yes there is just use your referral number before September 2nd and you will both get the promo
dust2dust
Just do it. You'll both get the promo. Make sure your code is correct and that the site gives you a green check mark. Even then there could be problems. This site has bugs aplenty.
Timer
@irisxiaolu
for today send by PM a  email about refer a friend will be starting today August 15th, until last day Sept. 2nd. for just one customer you will getting that credit.
then other friend #2, you will getting credit $1.
also free 2GB data
enter your email and the same email you will be activated
in here: https://publicmobile.ca/en/on/
