11-14-2022 10:20 PM
Hi!
I couldn't find the compatibility checker on the website. Is the Samsung A53 compatible with Public Mobile?
Thanks!
11-14-2022 10:38 PM
Yes, all newer iPhone, Samsung or Google phones are compatible with PM.
Here is a good website for device compatibility in Canada:
11-14-2022 10:28 PM
@anthonygreen wrote:Hi!
Thanks!
While compatible, the feature set looks beter than it really is. The Exynos 1280 processor makes this phone lag noticably and even very slow to boot up. The camera is flat out awful. Pictures were better from some lower end devices from 10 years ago. This isn't to say that this is a bad device. it's really not that bad of a device, but I wouldn't recommend it if you regularly take photos with your phone It really all comes down to the price that you're able to get it for (if you're thinking about purchasing this model).
11-14-2022 10:26 PM
@anthonygreen Yes, Samsung A53 will work.
But if you are getting non-North American model, let us know (although it should work still , but just in case)
11-14-2022 10:23 PM
@anthonygreen , the Samsung A53 is compatible with this service.
