06-17-2019 10:25 PM - edited 01-05-2022 05:26 AM
When browsing the compatibilty test they offer I cannot find the LG G6 on the list, so does that mean it is automatically incompabible with the network? I have the LG H873 if that makes the life or death difference.
06-18-2019 05:41 PM - edited 06-18-2019 05:42 PM
06-18-2019 05:37 PM
LG G6 is compatible with Public Mobile GSM, Public Mobile HSDPA and Public Mobile LTE.
06-18-2019 01:30 PM
@Catz-PJz wrote:When browsing the compatibilty test they offer I cannot find the LG G6 on the list, so does that mean it is automatically incompabible with the network? I have the LG H873 if that makes the life or death difference.
That's the phone my son uses. Works fine on PM.
One piece of BONUS info...
He was having a tough time with cutting out, horrible call quality, fading in and out, etc. I was hearing it first hand. Was very frustrating. After doing some research, it's a known issue with the devices. In the settings, under the following:
Call settings --> Advanced --> More
Make sure Noise supression is OFF. You should be ok with leaving Voice Clarity ON.
Good luck
06-18-2019 01:04 PM
An LG G6 if bought from a Canadian store new (or via a known friend or workmate) yes, it will be compatible.
The LG phones have a bad habit of requiring at least a network reset, if not a factory reset. Coming from Freedom especially.
06-18-2019 11:03 AM
@Catz-PJz I've had both the LG G3 and LG G5, so I don't see why the LG G6 wouldn't work. I'd say you're good to go. You can also check out GSM Arena for specs on any type of phone you're looking into. I use that site all the time, pretty detailed info there.
06-17-2019 10:59 PM
As per Dunkman, the H873 is compatible. You'll need to make sure that it isn't locked to another carrier. Some of these earlier batches were locked to a the carrier that sold it, while some of them had the word "unlocked" on the box's serial number/IMEI sticker.
06-17-2019 10:28 PM - edited 06-17-2019 10:38 PM
That LG phone is the Canadian version. Should have no problems with Public Mobile.
Here are the specs:
https://www.gsmarena.com/lg_g6-8466.php
| 3G bands | HSDPA 850 / 1700(AWS) / 1900 / 2100 |
| 4G bands | LTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 7(2600), 8(900), 12(700), 13(700), 17(700), 20(800), 25(1900), 29(700), 30(2300), 66(1700/2100) |
Public Mobile uses the following frequency bands:
