Is it possible to port your number over after the fact???
08-14-2016 03:37 PM - edited 01-04-2022 03:01 PM
I just set up two new public mobile account and they are working great, I chose a new number for the 1st one as the port wouldnt allow it to transfer but it worked for the 2nd number .. So my question is can i port over the number that failed after ive set the acct up etc.???
Thanks
Shawn
Service
08-14-2016 03:45 PM
Yes, you can change your number or port a number, even after the initial set-up.
08-14-2016 03:41 PM
Hi @Shawn82, welcome to Public Mobile! Provided that you kept your account active at the previous carrier on the # you didn't port, then yes you can initiate a port request at any time. Sign into your self-serve account for the line you activated with a new #, go tot Plans & Add-ons tab, and to the phone number change feature. There, you can request to port in the other phone number.
Hopefully that helps!
![](/skins/images/813D49D689E0D681E39391EAB60FD666/responsive_peak/images/icon_anonymous_message.png)
