Is it free to answer calls abroad? (outside Canada)with the plan 15$/month?
konigyong
Is it free to answer calls abroad? (outside Canada). with the plan 15$/month?
10 REPLIES 10
@konigyong
You probably won’t get the call since there are no Telus cell towers if you are outside of Canada.
I read this like @Anonymous does. I vote you.
darlicious
@konigyong
Umm... yes...sorta, kinda....in the US you would need a roaming add on** or a local or global sim card. Everywhere else on the planet you need the latter...a local or global sim card and/or wifi.
Before you leave Canada you download a voip app like fongo is good but you don't get free outgoing texts but very few ads or for premium subscription you get no ads and outgoing texts and other stuff for I think $4/month. Or get textnow for free with outgoing texts but a lot more ads...there are others too...
Then call forward your pm number to your voip # just before you leave Canada. (For this to work in the US you must remove the sim card so it doesn't connect to a US tower that will cancel your call forwarding. (**unless you bought US roaming add ons then it's a moot point.) If you have prepurchased a global or a local sim card you can replace the pm sim card with the local or global sim card when you are about to leave Canada.
Your voip app will work on wifi or mobile data now when someone calls your pm number it will ring thru to your voip app's #. Some places have free wifi almost everywhere like Dublin that even has it on public transit busses so you may not even need a local sim but plans are also so cheap in nearly every other country that you will get a healthy data plan w/calls and texts for about $10-$20/30 days.
Additionally you can also download a text forwarding app. For this to work with your pm service you must leave the pm sim card in a powered on phone and connected to the charger so it stays on. Leave it with trusted friend or family member who can monitor it every once in awhile. Now you will be able to get your pm calls and texts (and 2FA verification texts!!) wherever you are travelling and all on the $15 plan.
So yes you can answer your phone and pm won't charge you extra (ever!!) pretty much anywhere in the world when on wifi and/or mobile data from another provider and you can easily call home for free.
Happy travels and Stay--Safe!
popping
@konigyong
PM SIM card works in Canada and US with US roaming add-ons.
PM SIM card does not work in other countries.  If you travel outside Canada and US with roaming add-on, your phone will not ring.  You can get a local SIM card after arriving at your destination.
pkaraa
If your phone rings while away from Canada, you can receive that call, there is no extra charge for that.
Camera4617
You could forward your PM calls to some Voip app, if that's something critical to you.
darkomega
You would need to buy an international addon to call outside of Canada, only Canada-wide calling is included.
VIP_Tech
Hi @konigyong
in Canada unlimited incoming call from anywhere International all free plans include.
and for plan $15 outgoing 100 minutes Canada-wide,
here 30 days prepaid service no fees extra charges.
Edit: outside Canada you need to buy it U.S. roaming add-ons 10 day packages.
How To Purchase Add-Ons through Self Serve (publicmobile.ca)
U.S. Roaming (publicmobile.ca)
 @konigyong : Not entirely sure of your intents with your wording. Public Mobile only works while connected to the Public Mobile network. ie. in Canada. They offer roaming add-ons for use in the US.
You can receive calls and texts from anywhere on the planet...while in Canada.
@konigyong   No, it is not
You will need to buy Roaming add-on but PM only has US Roaming.  PM Does not offer roaming outside of US
[Update: My answer above assume you meant if you can answer calls while you are AWAY from Canada. ]
