Is My Rewards down?
JK8
Is anyone else having problems logging into My Rewards?
9 REPLIES 9
@JK8
Yes, I tried to login last night and it showed the same error.
I was going to check if I made any rewards for helping on this Community for January.
@hTideGnow wrote:
HI @Yummy   I can login now without problem
Thank you @hTideGnow . Yes, NOW (11:51) is working and NO, PM did not roll us to Points...😋
The dog is cute  🙂
So, maybe Database cannot access some user accounts only?  I can login and browse no issue
What is the idea of having this picture if page is unavailable?
Yummy
Yes, even now after 11 hours of initial post:
darkomega
@Anonymous wrote:
That's it...we're all being rolled over to Points 🙂 Telus has had enough of the shenanigans in their little gum and baling twine operation trying to sit unnoticed over there in the corner.
I honestly wouldn't be surprised if that happened 😛
Yes, it's down.
