05-08-2021 03:11 PM - edited 01-06-2022 02:00 AM
I can see that it is in the "coverage" zone by the maps. I just can't tell if it is in the allowed subscription area, or are these the same. Specifically Harcourt ON just west of Bancroft.
05-08-2021 04:11 PM
@joejays If your concern also relates to Port-in eligibility you can use this link to check mobile numbers: https://secure.koodomobile.com/checktransfereligibilityparrot/default.do?lang=en&appname=otherportal
05-08-2021 03:40 PM - edited 05-08-2021 03:41 PM
Bancroft and the surrounding area is well served by bell towers. Only the tower near Cardiff is lacking the 1900mhz band which should have no effect. Ask anyone that has telus/koodo/pm or bell/virgin/lucky service how their service is and you will know if their are any particular issues with signal due to topographical geography.
05-08-2021 03:28 PM - edited 05-08-2021 05:06 PM
If the area is provided service by either Telus or Bell - you'll be good with public mobile
05-08-2021 03:17 PM
It should have coverage based on the Telus towers which PM uses.
