03-08-2016 06:03 PM - edited 01-04-2022 12:50 PM
My phones IMEI is listed as not found with the Public Mobile checker.
I read here that as long as the network frequencies match the ones used by Public mobile, but I want to check that the Asus Zenphone 2 (ZE551KL) shown here is compatible before I sign up.
The Zenphone 2 uses these frequencies:
3G :
WCDMA :(US version)
850MHz(5)/900MHz(8)/1700MHz/1900MHz(2) /2100MHz(1)
4G :
LTE Bands: (US version)
2100MHz(1)/1900MHz(2)/1800MHz(3)/1700MHz AWS(4)/850MHz(5)/2600MHz(7)/900MHz(8)/700MHz(17)/800MHz(20)
SIM1 Support2G/3G/4G
SIM2 Support2G/3G/4G
Will my phone work with first mobile?
08-31-2016 12:38 PM
i ran my IMEI and it detects this phone on the PM website. This phone has 2 IMEI because this phone is dual simed. only SIM 1 can be used for data. SIM 2 is for voice
08-28-2016 04:06 PM
yes, i have this phone and it works 4g
03-09-2016 04:54 PM
Weird that they only list half of the AWS band 4 frequency for LTE... they should list both 1700 and 2100 (usually "1700/2100") for AWS. But it sounds like you should be fine, which was my understanding previously as well.
03-09-2016 10:31 AM
As a few others mentioned it does work. I also own this phone and can say it's 100% fine.
03-09-2016 07:28 AM
ASUS Zenfone 2 Laser ZE551KL
Canada Public Mobile
03-08-2016 08:33 PM
You can also check it out here: http://www.willmyphonework.net
03-08-2016 06:31 PM
www.willmyphonework.net is an excellent reference site to check phone compatibility.
PM operates on 850 and 1900 for 3G and LTE band 4 (1700/2100) plus the band 17 (700) for LTE-a is being rolled out in some areas.
03-08-2016 06:25 PM
Hi @deereb!
Looking at the band frequencies you have posted, YES this phone is compatible with PM.
It needs to be unlocked. Hope this helps.
