03-29-2025 11:43 PM
I have tried to use the Esim feature but it says my device is not compatible when I saw that iphone14 is compatible. Im trying to DK ut another way but I don’t know where I can find the QR code for the Esim outside of trying to do it through the pm app
03-29-2025 11:59 PM
Hey @Deemobile
I just did an eSIM for the 14 Plus. So it should work. Reach out to a CS Agent and ask them to send you one to your email to get going on it.
Please use the chatbot to open a ticket: https://widget.telus.tiia.ai/publicmobile/publicmobile.html?lang=en
If you receive an error message that you are unable to open a ticket, send a private message to a CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 .
