07-16-2024 09:05 PM
My iphone is only in SOS mode. Says iphone not connected to the internet. Works normally with wifi. ??
07-16-2024 09:51 PM
Ok EddieO. Thanks for your help and I will try your suggestions.
07-16-2024 09:47 PM
@mac22, At this point I would contact a CS_agent by opening a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
It sounds like it could be something on your account that they should be able fix
07-16-2024 09:44 PM
Yes I only have Public Mobile eSIM and it is enabled.
07-16-2024 09:42 PM
Yes eSIM is active.
07-16-2024 09:23 PM
Have you gone into your phone's cellular settings to confirm there are no other eSIMs active? Public Mobile eSIM should be enabled
07-16-2024 09:22 PM - edited 07-16-2024 09:22 PM
Check if your eSiM is active? Settings, cellular, SIMs
07-16-2024 09:12 PM
Yes I've tried that and more and all of Apple's suggestions. I have an esim in my phone.
07-16-2024 09:08 PM
@mac22, have you tried restarting your phone? Another thing to try is turning Airplane mode on and then off. If that does not work are you able to try your SIM card in another phone?
