Invoice Detail
hamraj72
Hi I was looking at the invoices and found that it just list the payment. is there way I can pull the detailed invoice.
Thanks
Hamraj
1 REPLY 1
hi @hamraj72
sorry, it is what it is , I don't think they can customize the invoice
But you can check with PM support agent directly.  Submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
