Invalid referral code
YweR
I'm a new subscriber but my referral code is invalid when my friend tries to use it.  Any suggestion?
2 REPLIES 2
eddieO
Best is to copy to clipboard and then send to your friend so that they are not mixing up O with 0 and 1 with l for example. Other than that you can open a ticket by clicking the orange circle at the bottom right corner to contact a CS_agent
Or...
You can click on the link below to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
@YweR
Common mistake with entering the wrong alpha/numeric number. Mixing up S/5, O/0 or I/1 so check your referral code and re-enter it.
