02-07-2019 09:12 AM - edited 01-05-2022 03:17 AM
Hi I bought two sim cards today. One for me one for my wife
I used Sim #1 to create my account. And I thought I could add Sim # 2 in the same account so I went to "plan and add-ons" and "Change sim Card" and punched in Sim #2 to add my wife's number to my account. I thought that's how I add second number in one account.
Later I found out that I can use only one number for one account.
Now Sim #2 works fine with my account but Sim#1 is deactivated I think.
I can't use Sim#1 to create my wife's account.
Is there any way that I can still use sim#1 to create my wife's account?
02-07-2019 09:25 AM - edited 02-07-2019 09:27 AM
Ok thanks @stonechucker i have edited my message!!!
sorry for you @hogujak...![]()
02-07-2019 09:23 AM
@Lieux, there is nothing the Moderator_Team can do to resolve this, other than providing the information I have just given in my response.
SIMs are only usable once, and when a sim card is changed on the account, the old sim is rendered inactive, and can not be reactivated.
02-07-2019 09:21 AM
@hogujak, you have now lost the use of SIM number 1. You will need to get a new one.
You will need to activate a new sim for your wife's phone under a fully new account with a different email address than your account. Accounts are unique to an email address, 1 sim per account.
There is nothing that can be done otherwise.
02-07-2019 09:21 AM - edited 02-07-2019 09:23 AM
I think you will need the help fo the moderator to fix that... @hogujak
and explain what happened...they will help you...wait few hours up to 2 days...![]()
EDITED....If @stonechucker said that it's irreversible..so it is...
