Invalid SIM
10-19-2019 01:48 PM - edited 01-05-2022 07:38 AM
I got my SIM card in the mail and had the account activation almost completed, there was an error that made me start all over again. And now my SIM card is "invalid" but it wont let me log on with the user name I created.
Help
Joining Public
10-19-2019 05:58 PM
Did you try InPrivate browser.
10-19-2019 03:15 PM
@KaraG wrote:I got my SIM card in the mail and had the account activation almost completed, there was an error that made me start all over again. And now my SIM card is "invalid" but it wont let me log on with the user name I created.
Help
There are also some caess in which the service doesn't work but your credit card is still charged. So, check if that happened, and if it did, don't try to acivate again. For that type of situation, only the moderators could fix this. They also may need to help with the set up of your self serve account.
10-19-2019 02:55 PM - edited 10-19-2019 02:56 PM
What happens if you try to create selfserve with the email you supplied at the signup and the number you picked
If that doesn't work you should contact moderators
10-19-2019 01:55 PM
I waited a full 24 hours before trying again, and cleared all browser history
10-19-2019 01:51 PM
Help
Wait an hour and do your activation process again. Make sure to restart you browser also.
10-19-2019 01:51 PM - edited 10-19-2019 01:51 PM
@KaraG Try the sim in your phone to see if it was activated. If not, try the activation again in an hour once the session lock has cleared.
