Invalid SIM
Bhaskar_
My phone is repeatedly going into “Invalid SIM”. It registers correctly each time I power cycle. But says “SIM error” or something like that and displays “SOS only” and “Invalid SIM” alternately. I haven’t done anything to the phone.
13 REPLIES 13
Bhaskar_
Thanks for letting me know.
Bhaskar_
I have an iPhone 8 Plus. It doesn't support eSIM. I will contact customer service as per your suggestion if the problem comes back again. It has been working for last 5 hours!! Thanks for your help.
Bhaskar_
Thanks for the suggestion. I will see how it goes. It is still registered (since I came back home). I will know later if it is related to cell handover. So far, after about four power cycles and being in the same cell coverage area, it is working. I will reach out to customer service as per @Handy1 suggestion if it happens again.
TheGx
This happened to me today and I had to restart my phone(not power off) by using the restart option on my phone but pretty sure that powering off probably works too...had to restart 2 times before my sim worked again...this happens to me about once every few months or couple times a year and not sure why...
That’s true in that case another option if your phone supports it would be eSIM also and you can do it right away $5 also @Bhaskar_
Chalupa_Batman
It sounds like you may need a new SIM card. Sadly they don't last for ever. A small blip of static electricity can wear it out. Follow @Handy1 suggestion of reaching out to customer service and see what their advice is. I think they'll say your SIM needs to be replaced. If they DO say that, don't buy it from them. I only say that because it will take weeks to get. If you have Amazon Prime, it's only $4.99 and faster shipping.
@Bhaskar_  Then I’d get support to investigate for you
private message   To CS_Agents click
Bhaskar_
No. I’m with Public Mobile for more than 4 years now. I am still connected with LTE since my last power cycle one minute ago. Don’t know how long it will stay connected.
@Bhaskar_  Check
Outage map in your area:
https://istheservicedowncanada.com/
@Bhaskar_  did you just join PM or change phones . Maybe you need support to re provision the sim for you in there end
Bhaskar_
*haven’t*
Bhaskar_
I have’s touched my SIM card in four years!
Chalupa_Batman
Did you put the SIM card in correctly? Sometimes putting it upside down can result in this error.
