Invalid SIM Card
06-01-2021 04:33 PM - edited 01-06-2022 02:12 AM
So, recently, my phone crapped out and I had to switch to a new one. However, when I inserted my Public Mobile SIM Card (that had already been activated in another phone) a notification popped up that said "Invalid SIM Card: Network locked SIM card inserted". At the moment, I can't find a solution to this problem. Some help would be very much appreciated. If it helps, the last SIM Card inserted into the phone was a Bell SIM Card
Phones
06-01-2021 05:52 PM - edited 06-01-2021 05:58 PM
06-01-2021 05:45 PM
@sithrolling wrote:No, I mean that there is nowhere to type in the code. I know that there is supposed to be a popup that appears when you put the new SIM Card in for typing in the unlock code. That popup does not appear
@sithrolling So the pop up message you were getting when you first inserted PM's SIM, no longer appears?
Perhaps you need to contact moderators for help. Here's couple of links, first try the chatbot and follow prompts to submit a ticket: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If unable to submit a ticket try sending a private message to Moderator_Team here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
06-01-2021 05:41 PM
06-01-2021 05:40 PM
do one thing take your SIM card out and waiting for a minute and put it back and do rebooting your phone - This one is quick and simple. Make sure your phone is off before removing and reinserting its SIM card.
Remove your phone’s battery - Some phones have removable batteries. Sometimes removing and reinserting the battery can fix certain issues. Just make sure your phone is off before you do this.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
suggest you if you can try your SIM card on other device.
and if you like to do your device for a factory reset.
06-01-2021 05:40 PM - edited 06-01-2021 05:41 PM
@sithrolling wrote:I tried it again and it still doesn't work sadly.
@sithrolling Do you mean the code you are entering is not being accepted? Just double check that the digits are correct when entering them.
06-01-2021 05:40 PM
That doesn't seem to have worked, unfortunately. I tried fully powering it off and putting the PM SIM Card in, and there was still no opportunity to type in the unlock code.
06-01-2021 05:37 PM
06-01-2021 05:34 PM
@sithrolling wrote:Oh, ok. How would I go about doing that?
@sithrolling Have you inserted the PM SIM into your locked phone yet?
Depending on the phone, it's a good idea to first power the phone off and remove the SIM from your previous provider and then insert PM's SIM. Restart phone and it should ask you to input the unlock code.
06-01-2021 05:31 PM - edited 06-01-2021 05:33 PM
Oh, ok. I'll give it a shot
06-01-2021 05:30 PM
@sithrolling wrote:I contacted Bell and got an unlock code, but there is nowhere to input the code.
@sithrolling I would try removing PM SIM and then reinserting it and rebooting your phone. The unlock code usually appears immediately after inserting a new SIM if the phone is locked IIRC.
06-01-2021 05:29 PM
06-01-2021 05:25 PM
I have the unlock code, and I've restarted my phone to use the new SIM Card. However, when the phone boots back up, there is nowhere for me to type the unlock code that I got from Bell in. The error message I got before is still there.
06-01-2021 05:21 PM
@wellis wrote:https://productioncommunity.publicmobile.ca/t5/Self-Serve/Bugs-quirks/m-p/545887#M42286
There is a section in this very helpful organizer by @Luddite that I believe tells you how to deal with this situation. Scroll down and you should see it. I’m not 100% sure if it applies, but I figured I should share regardless.
The issue in this thread isn't about self serve. Others have noticed that the phone is locked to another carrier.
06-01-2021 04:50 PM
Yes, as advised above, you could try to contact Bell for an unlock code.
If it is a Samsung phone, you can get the unlock code from there as well
06-01-2021 04:43 PM - edited 06-01-2021 04:59 PM
you need to unlock your phone.
and if you are a owner for any device phone you Contact the carrier to unlock for you for free.
06-01-2021 04:41 PM
@sithrolling wrote:So, recently, my phone crapped out and I had to switch to a new one. However, when I inserted my Public Mobile SIM Card (that had already been activated in another phone) a notification popped up that said "Invalid SIM Card: Network locked SIM card inserted". At the moment, I can't find a solution to this problem. Some help would be very much appreciated. If it helps, the last SIM Card inserted into the phone was a Bell SIM Card
@sithrolling It sounds like the phone is locked to BELL. Contact them to unlock it for you, at no charge.
You will need the IMEI - Dial * # 06 # to get it.
06-01-2021 04:41 PM - edited 06-01-2021 04:42 PM
