Internet usage
05-27-2023 05:01 PM
- Hi, I recently changed my plan to 15 gig for 40$. Now I checked my account, it doesn’t show my plan as 15gig. It shows only 10 gig!!! I bought 15 gig, not 10 gig, please let me know whats wrong!
Plans
05-28-2023 08:16 AM
hi @Yazzz do you have an Android or iPhone I ne?
05-28-2023 07:49 AM
@Yazzz Yes just wait for support to reply to you and get it sorted out and give us an update afterwards
05-27-2023 05:51 PM
No im sure that i picked the correct plan cuz i did it just a few days ago. I didn’t change my plan long time ago, it was just a few days ago. Do you think I just have to wait for that agent to reply my message?
05-27-2023 05:49 PM
@Yazzz Is it possible you selected the wrong plans a few months ago along side when they were offering the 15GB for 40 there was a 10GB plan there for $40 too other had that issues themselves …. Hate to see you leave PM has there’s power in numbers .. but I can certainly appreciate your frustration all the same
05-27-2023 05:46 PM
Thanks. I sent the private message, im waiting for response. However the reason I changed my plan was that in the last 2,3 months my data was dramatically disappearing! My usage was the same as before, but it was like something was eating my data in the first 4,5 days after cycle renewal! It was really annoying, i was getting messages saying I have used 75% or 95% of my data however I was not! Anyways i decided to go in a plan with more data but it seems like a scam, how is it possible to buy 15gig and they give you only 10! And also the usage it is showing it is not absolutely the amount of data that I was using. It is getting frustrating! I am thinking of moving to another company
05-27-2023 05:36 PM
@Yazzz At the end of the day thou if I were you I would also schedule plan change for next renewal in the new 20Gb for $39 plan
05-27-2023 05:30 PM
05-27-2023 05:29 PM
hi @Yazzz I don't trust the spinner, it does not work all time
Try login using Incognito/private/secret mode and see if you get correct reading
if still 1.5 gb, message support and ask
if you are on iPhone, reset data statistics so you can monitor usage on your phone
Android is easier, you can check usage on phone without reset
05-27-2023 05:26 PM
I did! It shows the same thing. Says I used 1.5 g out of 10 G! Why!!!
05-27-2023 05:04 PM - edited 05-27-2023 05:05 PM
@Yazzz Try this
simply try refreshing the page when logged in
also note there’s a better plan right now for 20GB for $39 be sure to change plan for next renewal and not immediately so you don’t loose money for current cycle
