Internet doesn't work
Gaurav_96
Hi
Suddenly Internet doesn't work. Switched off phone, changed Carrier to T mobile, At&t, Verizon etc hut nothing works. Roaming is on. It was working until a day ago. I am currently in US and I have US, Canada, Mexico plan 60gb Internet.
@Gaurav_96
Is your phone on the list of whitelist of phones that will work in the USA on VoLTE?
https://www.publicmobile.ca/en/on/get-help/articles/volte?_gl=1*1qks5fo*_gcl_aw*R0NMLjE3MzA4MTg5ODgu...
hi @Gaurav_96
what phone do you have?
do you have a Canada-US(-Mexico) plan or US roaming addon?
did you try changing network mode to 4G or LTE instead of 5G?
@Chalupa_Batman wrote:
https://www.telus.com/en/bc/outages
You can also try reboot your phone and Reset network settings.
Not sure that will help him as he said he's in the US currently. 🙂
Outage map might not work , but check if data all used and reset network will still help
@Gaurav_96 wrote:
Hi
@slusagm wrote:
Check My Account using Incognito mode and see if you used up the data
Check if your phone had a data limit set and of data saver enabled
check any network outage in your area
slusagm
