06-02-2023 09:49 AM
according to my plan I should be able receive and send international texts. This, however, doesn't seem to be the case. Can anybody help?
06-12-2023 02:35 PM
@JPM1 Something else to try if it happens again.
When you have trouble sending or receiving SMS, it's possible that setting network to 3G and ”forcing" change of your SMS settings may solve the issue.
This procedure will force the update of the message centre number. You can verify it in your message settings.
06-09-2023 05:28 PM
I'm not getting anywhere with my request. I should have International Texting (when I'm in Canada) and don't. I know that people I'm texting have international plans and it's time the focus was on Public's service and NOT other providers.
Basic question: If it is true that Public supports international texting while in Canada (as it's plan says), why is it not working for me!!!!
06-02-2023 10:23 AM
I have the plan with 15GB at 4G plus unlimited Canada-wide talk and unlimited international text. I still have 12GB+ data left over
06-02-2023 10:08 AM
My contact is in Switzerland. Could we test that?
06-02-2023 10:05 AM
@JPM1 - if you have them saved as a contact, delete the contact completely.
Try texting by entering the number without using the contact in your device. Remember to check how to call this country with proper country codes, and Canada's exit code and such.
Did you do other device troubleshooting like:
06-02-2023 10:02 AM
@JPM1 wrote:I can't say if the other person can text other numbers in Canada.
I'm using WIFI and IMessage works fine, just texting does not. Unfortunately I can't test my SIM in another phone.
@JPM1 if you are not sure they can reply to Canada for free, why not keep using iMessage (if they are on iPhone too)
or if you want to test SMS, tell us which country and we can tell you what number sequence to put in
06-02-2023 10:00 AM
06-02-2023 09:57 AM
06-02-2023 09:56 AM
@JPM1 which plan do you have now? you tried the international texting and the text didn't go through?
if so, which country you are texting to and which number sequence you put in?
06-02-2023 09:54 AM
and the person I'm trying to contact has international texting
06-02-2023 09:54 AM
I have noticed you had another post over a month ago about this @JPM1 .
https://productioncommunity.publicmobile.ca/t5/Get-Support/International-Texts/td-p/974885
Is the out of country person able to text others in Canada? If so, and they cannot text you, are you able to try your SIM card into another phone and see if the texting works?
Not sure if this is the issue (especially if you receive/send other texts normally) but both iMessage and Chat Features require a wifi connection or data to send/receive texts.
Disable your Chat Features:
In your previous post did you inquire with CSA about this?
06-02-2023 09:51 AM
I am in Canada
06-02-2023 09:50 AM
@JPM1 - Yes, you should be able to do this, only while you are in CANADA. Are you currently in Canada?
Remember the person you are trying to receive/send to must also have international texting abilities.
