11-18-2023 10:01 PM
11-19-2023 03:06 AM - edited 11-19-2023 03:07 AM
@Nijhum Check out airalo.com for data roaming for very resonble price. You can use any voip app like fongo for calling. You can forward your PM to number to a voip line before leaving Canada.
11-18-2023 10:22 PM
Hi @Nijhum
Public Mobile only works here in Canada and the USA using roaming add ons. I would recommend using a VOIP app like TextNow while in Mexico and use it on WiFi or perhaps you can buy a data SIM card while you're there. You can pick a local number to where you live now and call back home for free!
11-18-2023 10:02 PM
HI @Nijhum
sorry, no roaming service in Mexico
you have to use local data prepaid sim or travel esim in Mexico
