Intermittent Problems Making Phone Calls
ipk2
I've been a Public Mobile user for about a year, and there are 3 other PM phone lines in my household.  Always been happy with the service.
The past few days we've been experiencing really spotty service both at home and nearby.  Lots of issues with outgoing and incoming calls, including calling my VM.  Just wondering if there any known issues in my area.  I live in Toronto, North of 401 and East of Yonge.
Thanks!
ipk2
Thanks everyone for the suggestions.  They didn't resolve the problem, but the problem has seemed to fix itself after 3-4 days.
Cheers!
@gpixel
You are a fast study my friend!
@ipk2
If @gpixel troubleshooting  does not work ( it will) or you still have some issues with your voicemail then use the lost/stolen feature in your account....log in. Report phone lost. Log out. Wait 5 min. Log in. Report found.  Reboot phone.
@ipk2 try these
  • restart your phone
  • toggle airplane mode on/off
  • reset your network settings
plmzaqplmzaq100
I'm from Saskatchewan and have not had a problem
Staliger
@ipk2 Perhaps, just a little outage. If it will be the same tomorrow, I would contact mods to investigate.
geopublic
@ipk2 Hopefully it's a temporary issue, best to submit a ticket to PM and ask them to investigate. Click on the ? and type mod to submit a ticket.
