Incomplete Port
tbat
Hi I ported from Freedom yesterday. I was very careful to text YES to the freedom port request immediately as I read that was the main issue that could prevent proper porting.
I can make calls and it shows my correct number on my wife's phone caller ID.
My ESIM also shows the correct number so a partial port has been completed. On Freedom I was using a physical SIM and I kept that in my phone until I was sure the approval text went through.
At this time I cannot receive calls, or send or receive SMS, even though outgoing calls work.
I have opened a ticket with support but was  wondering if there is anything else I can try in the meantime.
Thank you!
Seafood85
Can you please send me the number to call. Thanks.
tbat
Ok great thank you for the quick reply!
hi @tbat
yes, It could be an incomplete port.  PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway),  you can submit  ticket by direct message:
