Incoming calls
Anthonymaguire1
Hey I'm having issues with my phone's long distance incoming calls can someone help me and local sometimes
A new thread has been started for this topic.
CannonFodder
You probably should have started a new thread, asking for help, rather than adding another issue in a thread already started, and apparently solved..... BUT, now that you're here, how 'bout some further info.
What sort of issues are you having - reception on those calls is poor, or you've found out later that you aren't actually receiving the calls that someone has placed.... something else???
Shyboy3850
Have you tried power of then back on. Maybe it might work.
