Incoming calls.
Armandito
I wondering why I getting calls only from public mobile?
2 REPLIES 2
Hi @Armandito
I guess you requested porting?  if it is, then the port was not completed.  Call the porting team and ask  I have sent you the number to the Community inbox.    Please check your Community inbox (envelope on top right), check for the number and call
HALIMACS
@Armandito
Try rebooting your device, resetting network connections, or toggling airplane mode on/off.
If that fails, contact support:
  1. Use the ticketing system for a faster response time. Click here to create a support ticket, then type Customer Support Agent, then Contact Us,  or,
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
