Incoming calls not working, "cellular number not assigned"
pdol
I set up my new Public Mobile SIM and everything works fine except I cannot receive calls. Anyone who calls me gets the error, "this cellular number you have called is not assigned".
Looking for help, thanks.
17 REPLIES 17
aghadimi
Please someone help me
I ported my phone from Wind since yesterday and my incoming calls not working
I sent may emails/comments but it seems no ine in PM doesn't care to look at the account. They already charged my credit card and took money and who cares I am getting service or not
My husband wanted to switch I told him not to do that because the service is awful and no one to answer
Antiloop
Both my sister and dad are having exact same problem.
Still no response from PM for two days now.
pdol
Private message @Mary_M
Presencegirl
I have this exact same issue. It's been over 48 hrs now. Can you please assist me aswell
pdol
@Mary_M should be able to help
Sg1
I need my number ported properly too. Everything works except when people try to call me it does not go through!!!
pdol
Thanks for the help in fixing the incomplete port, @Mary_M
pdol
Thanks, PM sent.
Mary_M
Retraité / Retired
Retraité / Retired
Hello @pdol
Welcome to PM & thank you for sharing your experience.
It appears as though the port did not process properly, would you please send me your ported number and the account number associated ? I'll complete the port for you.
Looking forward to it,
Mary
** Please do not post private info such as: phone number, account number, pin etc.. This is a public forum. **
pdol
Also, I just tried calling another phone from mine in the same local calling area (area code 226) and it doesn't go through, it just hangs up after 2 rings.  It's fine calling to other area codes.
pdol
When I make an outgoing call the proper number (the one I ported) shows up on the call display at the other end.
geogolem
When you make an outgoing call which number shows up on the call display of the person you are calling? Does this number correspond to the number that you wanted to port from your previous carrier?
JaK
@Shazia_K@Mary_M, can one of you take a look @pdol's number, seems to be an incomplete port.
pdol
@JaK wrote:
Hi @pdol
Or sometimes it just takes a bit of time working its way through the system...
It's been like this since Friday (3 days).
pdol
I ported the number.  I just tried removing the SIM and rebooting (twice).  Same issue still.
Outgoing calls work, data works, it's just incoming calls that don't.
JaK
Hi @pdol
Have you re-booted the phone (including pulling the sim for a few minutes and re-inserting it)?
If still the same tomorrow, let us know, might need moderator intervention.
NDesai
Did you port in your number? Or did you sign up with new number?
Try removing the sim and rebooting your phone.
