02-15-2023 05:18 PM
I join the Public Mobile on Feb.7/2023, but i do not get any incoming call. I call call out and send text, also i can receive text. My question is you ask my last provider about my port to transfer to you.
02-15-2023 05:42 PM
I hope you still have your old SIM because you need it to reply to the text confirming you are porting over to PM.
Also your old account must be active before you can port over.
If you don’t have the old SIM and closed your account. You need to purchase a new SIM and active the old account with the old carrier.
To have the porting process restarted for you. You need to contact a CS_Agent.
02-15-2023 05:32 PM
Hi @rajprem1976 your port did not completed
You missed the step to reply YES to approve the porting from your old carrier. Make sure your old carrier account still active. Call PM porting team and they can re-request the porting
Will send you the porting team number to your Community inbox
02-15-2023 05:22 PM
@rajprem1976 If you just ported to PM and missed the text porting team number can help start port process for you assuming you still have the old sim card from last provider will send you it private message
02-15-2023 05:21 PM
You can submit a ticket with Public Mobile representatives (CSA) for help; click this link for issues with transfer/porting of phone numbers over to Public Mobile.
Or, you can try calling the Telus porting phone number, which we are not supposed to post here. So, check your private messages I will send it to you there.
When the incoming calls stop on the previous provider’s SIM card and/or landline/voip account, that is a good indication the port is complete.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
