Inactive email
jlalond2
Email used to set up account is inactive. Need to change payment info and can't log in!  What do I do?  Simon is USELESS for this request.
@jlalond2
You can still use your inactive email and password then have the 2FA code sent by text to access your active account.
When it comes to changing the e-mail addres, please go back to SIMon and when there, type "change self serve e-mail address".
@jlalond2 only PM support will be able to help to change email address used on My Account.  Please open a Forgot Password type of ticket as follow:
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
