3 weeks ago
Very frustrating
I'm in the US and unable to make any calls!
I have the Canada/ US roaming package.
Have restarted my phone
My wife has same issue and had same package
So very frustrating!!
3 weeks ago - last edited 3 weeks ago
what make / model is your cell as not all will work in USA as they've shut down the 3G required for talk and now you must have a VoLTE enabled cell that's recognised by Public Mobile as not all are. Here's some reading and a device checker at bottom of page...
https://www.publicmobile.ca/en/get-help/articles/volte
Also...as long as you have Roaming enabled in the settings on your cell, you should be able to use data / text. You can use WhatsApp to make / rec calls from anyone who also has the free WhatsApp on their cell. TextNow is another free option...just need to select a free Cdn number to call/text and it also uses your data or local wifi.
