Important
Ravi9
How to set up a data in phone
sunflowershine
@Ravi9 If you don't have a data plan, you need to buy an "add-on". If you have a data plan, you have to turn on your "mobile data" button in order to tell your phone to access the network.
kb_mv
@Ravi9 If a restart (make sure mobile data is turned on after) doesn't get it working check your APN settings compared to below and change as required.
JK8
Have a look at this link for apn settings:
https://www.publicmobile.ca/en/bc/get-help/articles?q=Apn
Gunner123
@Ravi9 hi what type of phone is it? does everything else work?
would be nice if you can provide more information, like what issues you encountered.
Generally, make sure you have data turned on.
If there are issue, check the WAP settings
