Im wondering why i cant add my minutes to my account
04-01-2023 09:09 AM
I'm just wondering why i cant add my minutes to my account on public mobile
Joining Public
04-01-2023 10:06 AM
@Hoodyjr we tried to help yiu on your other thread. Please refer back
https://productioncommunity.publicmobile.ca/t5/Get-Support/Cell-wont-call-out/td-p/966565
04-01-2023 09:35 AM
Please also try to call 1.855.4PUBLIC and enter your phone number, that works like *611.
If that does not work, too, You can open a ticket with PM support and they can apply the voucher number for you
1. Please open ticket via Chatbot (need access to My Account): click this Chatbot Ticket Link
Then click "Click here to submit a ticket ↗" to open the ticket submission page
Next, enter your Community login, then enter your question. Finally use My Account login or 4 digits PIN to validate.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
04-01-2023 09:33 AM
Im not good with computers an cells lol theres no way i can give u my numbers off the receipt an u put it on 4 me please
04-01-2023 09:31 AM
You should be able to. Is your account listed as active on the self-serve page?
Make sure to log in using incognito or private mode
04-01-2023 09:30 AM
@Hoodyjr so, your account is suspended?
Yes, there was problem with *611, you have been using *611 to top up?
Can you login to My Account to make a top up there or login to My Account to check the account status?
04-01-2023 09:29 AM
Can someone help me an tell me why i cant add my mins 2 my public mobile account please
04-01-2023 09:25 AM
Wondering if u got my message about not letting me top up my account
