06-06-2021 11:46 PM - edited 01-06-2022 02:50 AM
06-07-2021 09:52 PM - edited 06-07-2021 09:56 PM
contact customer support mods
please click on the green chat bubble to the bottom right of your screen to speak with SIMon
type "moderator
(use the chat bubble options, then click "contact moderator", "click here to submit a ticket!)
*login using your community account
make sure to check your inbox(top right corner envelope icon) periodically, for a response
06-07-2021 11:13 AM
As many others have said, I’d try basic troubleshooting techniques such as taking out the SIM card and wiping it, restarting your phone, checking your settings for any unwanted options that are toggled on or off etc.
06-07-2021 06:34 AM
Consider:
Rebooting your phone
Removing sim (and then putting it back)
The next step I would try would be on Publicmobile.ca pausing the plan and then reconnecting.
More clarification would be great though, could you specify if it worked previously?
06-07-2021 06:09 AM
@Jamesnato wrote:It was working this morning and now i cant get any service
First, check to see that you have data left by going onto your Self Serve account and seeing that the data line is still showing. IF it is gone, than you used it all up.
Perhaps your SIM card shifted inside the SIM slot. Remove your SIM and gently clean the contact of the SIM card; gently blow inside the SIM slot.
Once the SIM is inserted again reboot your phone.
IF still issues go into airplane mode for few minutes, then go back to regular mode.
06-07-2021 01:06 AM
@Jamesnato Do you see Public Mobile on the left hand upper corner of your phone?
What is the wording on the location if it is not Public Mobile? Is it Emergency Call or an airplane icon or something else?
06-07-2021 12:00 AM
@Jamesnato : See what result you get with devicecheck.ca
06-06-2021 11:57 PM
try to reseat the SIM (power down, take sim out, wipe and put it back and power on)
06-06-2021 11:56 PM
Nothing works
06-06-2021 11:56 PM
@Jamesnato wrote:Do u mean reset
Yes, turn off your phone and the re-start. Basic troubleshooting step. You may have already tried this step.
06-06-2021 11:55 PM
I have the 50 dollar plan and yes its active
06-06-2021 11:55 PM
My payment was last week and it was working fine this morning
06-06-2021 11:54 PM
Do u mean reset
06-06-2021 11:53 PM
@Jamesnato no incoming calls or outgoing calls?no text? no data??
what kind of plan do u have?
did you login Self Serve and chexk if account is active?
06-06-2021 11:52 PM
Nothing is working
06-06-2021 11:51 PM
More details would be helpful.
Is anything working? talk, text or data?
In your self service account, is your status active or suspended?
When was your payment date?
Try rebooting your phone.
