IPhone SE
TennehF613
I just got an iPhone SE, and its network carrier is Public Mobile. I am trying to switch my SIM card to the new phone but it says the fllowing:
SIM Not Supported
The SUM car that you currently have installed in this iPhone is from a carrier that is not supported under the activation policy that is currently assigned by the activation server. This is not a hardware issue with the iPhone. Please insert another SIM card from a supported carrier or request that this iPhone be unlcked by your carrier. Please contact Apple for more information
The problem is, the SIM is from Public Mobile, and the Phone's carrier Public Mobile 2.0! I have tried calling Public Mobile but the calling centre doesn't seem to exist anymore.
ANy help is appreciated!
TennehF613
But the iPhone says the carrier is Public Mobile (when I check Settings -> Network -> Carrier).
TennehF613
When I check this, it says the carrier is Public Mobile. Hence my confusion!
JackQuint
As already posted, you are locked to a different carrier.
If you check in Settings/Cellular/Network Selection should tell you the last successful carrier connect which should let you identify who it's locked to.
Carriers have to unlock for free and it should be just a phone call. If you can't identify the carrier, start with Rogers, then try Bell, then try Telus, etc.
That is unless your phone is blacklisted as being stolen. In that case, no one will activate. When you check the compatibility here: https://www.publicmobile.ca/en/bc/get-started it will also tell you whether the phone is blacklisted.
Lieux
SIM Not Supported
Looks like your iPhone is not unlocked.
You'll need to confirm this by putting the PM sim in a confirmed unlocked phone to see if that works. If so, you'll need to contact your previous cell carrier of your iPhone to have it unlocked.
