08-13-2021 02:04 PM - edited 01-06-2022 03:07 AM
08-13-2021 03:52 PM
Generally, iPhone will work on PM
Generally, any phone designed for North America (North American version) and selling in Canada will work on PM
The questionable phones are those that are non-North American version and phones that designed for regional markets. Those phone might not work at all or even it works, it has less matching bands PM uses and hence the reception can be awful in areas.
Stolen phones are more common that we thought. Just be careful
08-13-2021 03:42 PM
for "blacklisted" is stolen device like 1% you will found it and i don't think so the will sell you know
and for the "blacklisted" device is can use by only wifi is will working but not put it any SIM card.
08-13-2021 03:20 PM
@Anonymous
Good points! That crossed my mind as well but is still something that reduces the mobility of transferring SIM cards around. From what I recall, Canada has also never had an issue with SIM-locked phone so I didn't mention that. Perhaps I should have mentioned "blacklisted" phones as well, but generally shouldn't work on any provider (as opposed to being able to be transferrable with Public Mobile). Regardless, good points for added info for any future readers!
08-13-2021 03:12 PM
just to you know
Canadians have the right to buy wireless devices like a smartphone without being locked to a service provider's network. All phones sold in Canada since December 2017 are already unlocked. Older devices can be unlocked by the wireless carrier at no cost to the customer.
and if you buy it from any retail store like apple all device is be unlocked.
08-13-2021 02:55 PM
Yes, the iPhone 12 will work with Public Mobile as others have mentioned.
Most recent/modern phones will work fine with Public Mobile... these days they take SIM cards which allows you to move your service between phones at your convenience. The biggest question is usually about whether the phone is Locked or not, and what frequencies the phone works on. Generally, frequencies aren't an issue, but feel free to check in with us if you're ever curious about this (just like you did here). 🙂
08-13-2021 02:07 PM
08-13-2021 02:05 PM - edited 08-13-2021 02:05 PM
Yes is will working 100%
