04-10-2024 12:59 PM
So I was subscribed to the $34 50GB US/Canada plan and I see it has expired. Does that mean that my plan goes away and I have to pick a new one or does it get grandfathered in and remain the same until I change it?
04-10-2024 01:08 PM
I understand your confusion, indeed. (It's a common result of PM continually confusing messaging) As long as you had autopay enabled, your plan will continue to renew the $34 Can?US plan every 30 days until you change it.
04-10-2024 01:05 PM
@Wardey Are you on the old loyalty rewards right now ? If some come may you will pay full price for the plan $34 + tax . Then when you have earned 15 points you can redeem $15 off your bill from the rewards portal .
04-10-2024 01:02 PM
I hope so. It's funny because on the website it shows that i will renew with the existing Canada/ US plan, but on the mobile app it says I will be renewing at a higher priced Canada only plan.
I took a screenshot of the website for backup if I need to prove my point.
04-10-2024 01:00 PM
it'll be your on-going plan unless you change it yourself. Once plan renews, you should see it's still yours.
