I was looking in Self-Serve Portal on plans for another A/c, and the options don't display
makkahn28
@makkahn28
Yes, just a finicky website thing that can happen.
Try opening a tab in incognito mode, you can also use a keyboard shortcut to open an Incognito window:
Windows, Linux, or Chrome OS: Press Ctrl + Shift + n. Mac: Press ⌘ + Shift + n.
TheGx
@makkahn28 :Look in top right corner of overview in your self serve, in it white box with bunch of zeros in front of it.
@makkahn28 wrote:
The website not showing plan details happrns on a regular basis. Please try again later.
@makkahn28
i suggest you can try to Logout and after 2 minutes log in.
and you can try it for a different Browser
and clear cache and cookies for any Browser,
and use a Browser from your computer,
and just make sure your Browser is up to date update
sometime is the Browser is not update is give a issue.
and Restart your computer, is will help.
and if you use a home internet please do one thing take it your power internet for about a minute and put it back,
makkahn28
This on my Laptop using Google Chrome
