05-07-2024
06:36 PM
05-08-2024
02:28 AM
computergeek541
05-07-2024 06:42 PM
Any data received as a gift or an add-on has a expiry date. If the data is because of the Public Points moving migration then you have 150 days to use it. If its from anything most likely its 30 days. If you sign onto your account in the app or online it will say. Just look for the data and under it will be the expiry if any.
05-07-2024 06:39 PM
hi @Nicko72 is your 30GB the special loyalty bonus?? If it is, it is a 150 days bonus. Login to My Account and it will show how many days remaining
the loyalty data will be used after your regular data allotment is used up. since the loyalty data has an expiry, used them and no point to save
