I want to update credit card
05-23-2019 12:43 AM - edited 01-05-2022 05:02 AM
05-23-2019 11:00 AM
@NDesai wrote:
@Anonymous wrote:If your credit card has an expiry of 2025 then you'll need to contact the @Moderator_Team < Click this.
FYI, this issue has now been fixed. We can now chose the year till 2030.
@NDesai Good to know. Thanks!
05-23-2019 10:44 AM - edited 05-23-2019 10:44 AM
05-23-2019 01:42 AM - edited 05-23-2019 10:00 AM
@Gideon Click the My Account buttom top right of this page.
1) Login to Selfserve, click Payments & Add-ons tab.
2) Below "One Time Payment" and "Manage Auto Pay" options there is a very small link
"Manage my card - Update or remove my Credit or Visa debit card"
3) two options are available: "Replace this credit card" and "Remove this credit card"
Use "Replace this credit card" to update the CC info
Note: When entering the postal code do not enter any spaces. Also do not use the unit number field even if you live in an apartment or condo and use a desktop browser if you can.
Hope this helps!
05-23-2019 12:47 AM - edited 05-23-2019 12:48 AM
Type in the bigger box below all the little icons.
Otherwise, in the payments screen, click on the little orange line of text lower down. Then you can remove or replace your card.
A couple picky site things: match the billing address and don't use the unit # field and max 6 characters for postal code ie. no space or drop last #.
