12-06-2021 02:48 PM - edited 01-04-2022 04:55 AM
12-06-2021 03:03 PM
Does she remember the email she registered with. Else try 'forgot password' with all the possible email addresses she can think she was using at the time of account creation. One of them should work.. check spam folder as well.
Second option is to contact support agents by clicking the blurb on the bottom right and open a ticket, they ll be able to help you after authorizing your account.
Keep us posted.
12-06-2021 03:01 PM - edited 12-06-2021 03:05 PM
@davidsbuchanan : You can buy vouchers in many stores or online and redeem them through the 611 service or also 18554public. Or do instant top in a few stores.
There might be some current problems with vouchers though.
Edit: if a payment card is already registered then you can also use 611 and toll free to make a payment. You'll need the 4 digit account though.
12-06-2021 02:55 PM
@davidsbuchanan did she or you try the forgot password link?
Try with the different email addresses you might have used. If you got the correct one, you will be asked to answer the security question.
If you are unable to reset it that way, you will have to open a ticket with PM Support. click on the Bubble on the lower right or directly at : https://publicmobile.ca/chatbot.
Follow these these to get to ticket open page quicker:
12-06-2021 02:54 PM
in the login screen, just below where you enter the password, there is a a link to "forgot password. You should get an email with instructions on how to change the password.
12-06-2021 02:51 PM
close all Browser and do clear cache and cookies for any Browser,
and try open one Browser incognito mode,
you can try Forgot your password visit Here link, and enter your email address,
check your email spam,
or you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
them can solve your issue, they are nice Service Team they will help you 100%.
and them will reset for you,
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
Good Luck.
