08-08-2019 04:32 PM - edited 01-05-2022 06:19 AM
08-08-2019 04:42 PM
@Stacey14 wrote:I want to purchase a US add on
You've rec'd clear instructions on how to buy the 10 Day Us Roaming Add-on. Please be aware that the 10 days take effect as soon as you buy it.
If you buy it at 10pm...that will be counted as day 1. Plan your purchase accordingly.
Safe travels.
08-08-2019 04:37 PM
the first step is to load the money to your available balance, the second step is to select the add on and add to your account.
08-08-2019 04:35 PM - edited 08-08-2019 04:39 PM
@Stacey14 you can do so on the self-serve website easily. Click the "Purchase Add-On" button after you log in and then just choose the add-on you want added to your account. (And, of course, ensure you have the appropriate funds available too) ![]()
08-08-2019 04:35 PM
@Stacey14, add-on purchase is done in the self serve account. The following link provides an excellent illustration of the process. Give it a go.
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/m-p/198974
