I've purchased 1gb of US Roaming data but I've got no data signal since I arrived in New York
01-23-2020 10:18 AM - edited 01-05-2022 09:09 AM
01-23-2020 01:21 PM
@srlawren wrote:
@gblackma wrote:There was similar complaint involving 2 roaming packages purchased for the same period in time. In short, one of the packages had to removed by a moderator before it would work. Maybe that applies here.
@gblackma @LovesToPM I don't believe that issue affects the data roaming add-ons, only talk and text roaming add-ons.
Thanks for sharing that!
01-23-2020 01:16 PM
01-23-2020 10:53 AM
@Pvalerio Otherwise if the problem persists, @gblackma may have a point.
And you'll have to contact Moderators for help.
To submit a ticket to Moderators: Click the green question mark at bottom and enter your question into SIMon. Answer the prompts until you get to the Contact Us button, click it and a Submit Ticket button should appear.
If you encounter problems with submitting a ticket, you can send a private message to Moderators, but this alternate contact method may have longer response time.
@Pvalerio wrote:US Roaming 1 GB Data (10 day)
US Roaming - 500 MB Data (10-day)
This is what it says under my ad-ons, and my available funds went down when i purchased them. however, on my phone, i'm connected to T mobile, but instead of 3g/4g etc, it just says LTE and doesn't load anything on the internet
01-23-2020 10:52 AM
01-23-2020 10:52 AM
First off, was your APN (for mobile data) already working on your phone while you were in Canada?
If yes, don't touch your APN settings. Go to your phone settings and try manually connecting to AT&T (instead of T-Mobile). As mentioned by others, make sure data roaming is enabled on your phone. Does that work better?
01-23-2020 10:44 AM
01-23-2020 10:40 AM
01-23-2020 10:39 AM
US Roaming 1gb data 10 day
This is what it says under my ad-ones, and my available funds went down when i purchased them. however, on my phone, i'm connected to T mobile, but instead of 3g/4g etc, it just says LTE and doesn't load anything on the internet
01-23-2020 10:29 AM
@Pvalerio wrote:Please advise. I will check this post again later.
Peter
Logon your account and check under "My data and Add-ons". If you see the US Roaming add-on listed there, it is active and is good for 10 days.
Read here for some troubeshooting tips: https://www.publicmobile.ca/en/bc/get-help/articles/us-roaming
01-23-2020 10:23 AM - edited 01-23-2020 10:24 AM
Peter, sorry to hear about your problem. Did you turn on data? Roaming? On my Samsung phone, I have to turn off WiFi to use data.Dont know why.
Peter
01-23-2020 10:22 AM - edited 01-23-2020 10:23 AM
Peter
Can you manually select AT&T or T~Mobile network. Do you have data roaming turned on in your settings?
Purchasing addons is a two step process. Here is a great tutorial on how to purchase addons created by @srlawren https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/m-p/198974
Have you done the two step process
01-23-2020 10:21 AM
It's two steps to buy an add-on ..log into self serve account and see if you have a balance...
If you do then you have to purchase it now.
Guide below ..
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/td-p/198974
If you did both steps...try manually selecting a network..from att to T-Mobile or vice versa.
