I’ve bought 2 $60 vouchers and I get the message sorry invalid numbers?
Knichol
darlicious
@Knichol
Depending where you purchased your vouchers they can take up to 24 hours to become valid. Check and see if they are represented in the voucher catalogue it can give you some insight into your vouchers. If they are not represented please consider adding them after you have successfully loaded them onto your account.
https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/Voucher-Catalogue/m-p/479165#...
 @Knichol
You can also try it using the 611 service. Make sure you're using the right set of 12 digits if you have more than one. It's silly how they print these things out.
@Knichol Wait a few hours before trying again. Sometimes, there is a delay after purchase.
