I order Us roaming text, talk, and 200 mb data...
stefdav55
I am getting the talk and text but not the data. I am traveling and this is BAD when I am trying to find things I need on the road. It shows on my acct that I should have all three. What do I do? I am already 4 days into this.
16 REPLIES 16
NDesai
@stefdav55 Do you have Roaming option turned on in network settings? Does your phone connect to AT&T or T-Mobile network at all?
Edit: You might want to go through these troubleshooting steps: https://www.publicmobile.ca/en/bc/get-help/articles/us-roaming#:~:text=Troubleshooting%20U.S.%20Roam...
_________________________________________________________________________________________________
If you need to contact PM Customer Support Agent, create a Ticket.
New Here? - Check out Knowledge Base Articles to learn more about Public Mobile.
darlicious
@stefdav55
Have you....
  1. Enabled roaming.
  2. Rebooted your phone.
  3. Manually chosen either at&t or T-Mobile?
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here   ....for additional member supplied info.
stefdav55
Yes I have roaming enabled. I am getting talk and text...just not data. I am using T-Mobile
stefdav55
I will reboot right now and see if it does anything.
stefdav55
LOL! I should know to reboot but I didn't think of it. And I won't be able to tell if it did indeed work until we leave this motel tomorrow. I guess I'll have to wait. Darn!
dust2dust
Turn off wifi, turn on data - can you get to a web site (preferably simple to not download a bunch of crap).
stefdav55
Okay...I did that but it's the same. It just buffers until it says it timed out.
stefdav55
...and then it says there is no internet connection.
dust2dust
Do you see mention of roaming data in your my data & add-ons on your overview page? Maybe you used it all. 250mb is not a lot of data.
