04-19-2022 11:57 PM
I'm trying to change my email on my account I can't seem to change it the email no longer exists how do I put a new email on my account I believe the system wants to send me an email to confirm I want to change my email
04-20-2022 12:02 AM
@Brew12601 Even the email you are using for My Account does not exist, you can still use it to login to My Account (afterall, it is used as a user id here anyway)
Of course, it is good to change it to an email address that you have access. But only PM Support can assist in changing the email used for My Account, please open ticket with PM Support:
1. If you have access to My account: Click on the bubble on the lower right or https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
04-20-2022 12:01 AM
@Brew12601 wrote:I'm trying to change my email on my account I can't seem to change it the email no longer exists how do I put a new email on my account I believe the system wants to send me an email to confirm I want to change my email
There isn't any way to change the e-mail for the Self Serve account that you can do yourself. You'll need to go open this link at https://widget.telus.tiia.ai/publicmobile/publicmobile.html and after doing that, type in "change self serve e-mail address".
