I need real support
Al72
I am getting SIM card puk, I don’t have this and near did. I have submitted a ticket but no fix yet? Does someone know what to do
2 REPLIES 2
@Al72
If you have an iPhone, you can disable the SIM PIN setting.
If it is not an iPhone, contact a CS_Agent to look up the PUK for you.
@Al72
what was the exact error message? Depends on the message, you have to ask the PUK code from different places
If it is a Samsung and if the message is "SIM network PIN blocked. Enter SIM network PUK."
call  Samsung 1-800-726-7864, The only info you will need to provide for a master unlock was the IMEI and where the phone was purchased
If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM cannot be accessed" or on an iPhone's status bar showing  "Locked SIM"
open a ticket with PM Support using this direct link:  https://urlshortner.tiia.ai/Oyn1L6
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
If the message is "SIM network unlock PIN" or "SIM ME lock code NP"  or  on an iPhone's About->Carrier Lock showing "SIM locked"
You have to ask the carrier where you got the phone from for the carrier unlock code. (PM would not be able to help with this)
