05-16-2021 04:04 PM - edited 01-06-2022 02:43 AM
I need more time tiling can pay for my monthly payment for the month of may forward as I'm just short on money at the moment
05-17-2021 02:01 AM
Out for some spring phishing?
05-16-2021 06:13 PM
@Quigley... that's so very kind of you to offer the OP that, good for you. 🙂
05-16-2021 06:11 PM
@Weezi6624 send me a message and I'll help cover your cost.
05-16-2021 04:53 PM
If downgrading to the $15 plan is not an option for financial reasons or your plan is grandfathered then consider downloading textnow for free texting and fongo for free calling while on wifi (fongo also works on mobile data FYI for future use) to tide you over til you can pay and reactivate your plan. If you have not hit your renewal yet you can suspend your service on the 30th day via lost/stolen. This will retain your voicemail access and keep it active. You could change your greeting asking callers to leave you a message or callback number. Then when you can access wifi you can check your messages and return calls.
05-16-2021 04:35 PM - edited 05-16-2021 04:37 PM
@Weezi6624 What plan are you on...if you're not on the $15 plan then perhaps you could opt to change plans to a cheaper one for this cycle in order to keep your phone services going?
Just a reminder that if you are on discontinued plan and have been grandfathered into your plan, then any changes in plans will mean you will not be able to go back to your old plan.
05-16-2021 04:12 PM
@Weezi6624 : Prepaid providers generally don't have extensions. You pay in advance then times up. I have found that the actual services might keep working until maybe mid-morning after the end of a paid term.
You can tie yourself over using a voip app on wifi like TextNow that also does talk.
Your account can be re-started up to 90 days after it ends to keep it alive...just not working.
05-16-2021 04:11 PM
Hi @Weezi6624... we're users helping users, and if you're a bit short, there's not much that can be done being a pre-paid service.
Some ideas...
Can a friend/family member spot you a few $ for you to renew your plan this cycle?
05-16-2021 04:11 PM
@Weezi6624 Your account will suspend if you don't make a payment and you then have 90 days from that time to make a make a payment before your number and account would be deactivated and lost.
