I need help
RB06
My previous phone had an eSIM. And i do not have access to any other device to help me out. So I purchased a physical card. To no avail. Someone please help. It’s Christmas and I will not be able to speak to some of my family.
drkuh90
Download the PM app on your new phone, enter your log in details and when it sends the 2FA code to your number click on “Didn’t Get a Code?” The. You’ll be able to select to have the code sent to your email. Once you’re logged in go to the “Account” tab and you can change your SIM card number there.
hi @RB06
i think the reason you cannot use eSIM now is the login issue.  PM support agent can help to update your physical sim card number
 you can submit  ticket by direct message:
Socrates8567
Hello @RB06
This is very simple. Just download the pm app on the new phone of your choice, purchase a new eSIM and when you get to the check out, it will be free. Easy as that.
