I need help with payment
Kickazzcrissy
I tried a few different ways to make a payment and it will not go threw.  My bank says its approved but its only going threw at zero dollars.  Please help
@slusagm wrote:
wait 24 hours and try again. Try using PM app and make sure you give the app location permission
if you need to pay now, use voucher. Buy from stores and call *611 to load the voucher
Having locations permission turned on for the Public Mobile app isn't a requirement.  It may have been required at one point, but I have done a few credit card updates recently (changing to a renewal card) and purposely disabled location permissions to test this out.
slusagm
eddieO
@Kickazzcrissy can you confirm if your services are working (calling, texting, data)? sometimes customers have reported getting a message about needing to pay even though they did, sometimes there's a delay in the system but as long as services are working you should be fine
If you go into the PM app you should be able to look up your payment history to see if there is something there. If you are still having issues contact a CS agent. To open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
