I'm overseas, can I receive SMS messages sent to my Toronto number?
fast1fred
I'm currently overseas and still have my Public Mobile SIM card installed. I need to receive an SMS message sent to my Toronto number. Is there a way to do this? Using WhatsApp or other dada messaging app isn't an alternative . It's only via SMS it can work.
will13am
Public Mobile does not have any roaming partners outside of the US.  I doubt that it would be possible to connect on any carrier network.  As an aside my suggestion is to buy a service locally or rely on wifi.  There are lots of communication apps that do not rely on use of a phone number.
Mana
I don't think its possible in that case.
Your PM service won't work overseas.
KMG
This can only be done if you are in the US, and if you purchase the US text add-on.  It is not possible in any other country.
